| gothspeed |
Jan 16 2018, 07:34 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I think I have covered the most common Fuchs wheel size combos for a GT tribute or clone. This would be for aggressive street and possibly light track use. Pick a wheel size combo that you think looks best in your opinion. Then list your reasons ... (IMG:style_emoticons/default/beerchug.gif)
BTW I am certain most have seen this article on Eric Shea's GT: http://www.retromodmag.com/features/porsche-914-6-gt Edit: please post pics to further illustrate your preference! (IMG:style_emoticons/default/smile.gif) |
| GeorgeRud |
Jan 16 2018, 08:05 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
They hold enough rubber and look period correct. The larger diameter always looks funny with sharper sidewalls. Wider front wheels create a larger scrub radius that makes steering at low speeds harder.
| EdwardBlume |
Jan 16 2018, 08:07 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
These cars don't always measure the same in all 4 corners, but do what you like the best.
| Mueller |
Jan 16 2018, 09:47 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Research what rubber is available before you pull the trigger on a particular size wheel.
Example, 245/45-16 , tirerack shows 10 brands however 5 are race only. Just something to think about |
| Justinp71 |
Jan 16 2018, 11:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,647 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None
15's (7/8) look the best!
Also I think having the width to rim ratio match front to back is important too. for example use a 7" tire on a 7" rim and an 8" tire on an 8" rim... Attached thumbnail(s) |
| larryM |
Jan 17 2018, 12:48 PM
emoze ![]() ![]() ![]() Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California
| gothspeed |
Jan 19 2018, 04:23 PM
Here is an interesting set of 7's and 8's x 16's (IMG:style_emoticons/default/smile.gif)
| mepstein |
Jan 19 2018, 04:59 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,916 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
The big difference between the wheels is the 8x16 & 9x16 will cost you multiples of all the other sizes.
| Racer |
Jan 19 2018, 05:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
It all depends on tire availability.. which could be limited in both 15" and 16" diameters.
That said, I liked one I saw with 8x15 fronts and 9x16 rears. |
| sixnotfour |
Jan 19 2018, 05:24 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,369 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
These cars don't always measure the same in all 4 corners, but do what you like the best. True that ,,I made Eric some custom 9 x 15s...noway would they fit his flairs...any body want some 15x8 weidman rsr finish with one inch added to the inside ?? 15x9 Me...8 & 9 x15 with dot race tires 245/225/ 50 Attached image(s)
| sixnotfour |
Jan 19 2018, 05:34 PM
what no 10.5 & 12 x 17 ??? (IMG:style_emoticons/default/beerchug.gif) 315/35 dot race tire
| ConeDodger |
Jan 19 2018, 05:35 PM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,584 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Rocky Mountains
So far I’m the only 7X16 front 9X16 rear. My rears are actually custom built Weidman 8.5X16 but that isn’t a poll choice. My reason for going with these is tire option availability and the fact that it perfectly fills the wheel well in the rear.
Attached thumbnail(s) Attached image(s)
| mepstein |
Jan 19 2018, 05:36 PM
| Spoke |
Jan 19 2018, 05:59 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,429 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
So far I’m the only 7X16 front 9X16 rear. My rears are actually custom built Weidman 8.5X16 but that isn’t a poll choice. My reason for going with these is tire option availability and the fact that it perfectly fills the wheel well in the rear. What's with the smoke screen? Great looking car. Attached image(s)
| gothspeed |
Jan 20 2018, 02:45 PM
Wow, I forgot about the Weidman option. They have the nice 'small' taper of the 15" in the rear, with the full diameter of the 16" ..... is that widening service still available? they do look great, thank you for posting (IMG:style_emoticons/default/beerchug.gif)
| mepstein |
Jan 20 2018, 02:59 PM
#16
Wow, I forgot about the Weidman option. They have the nice 'small' taper of the 15" in the rear, with the full diameter of the 16" ..... is that widening service still available? they do look great, thank you for posting (IMG:style_emoticons/default/beerchug.gif) Yes. Just open wallet and wait. He's still the best. |
| ConeDodger |
Jan 20 2018, 04:19 PM
#17
So far I’m the only 7X16 front 9X16 rear. My rears are actually custom built Weidman 8.5X16 but that isn’t a poll choice. My reason for going with these is tire option availability and the fact that it perfectly fills the wheel well in the rear. What's with the smoke screen? Great looking car. Got $10K? I need a top end rebuild. But, I’ve still got one kid in college and another project car. The 240Z is getting a stroked fuel injected 300HP... BTW Spoke, besides 914Rubber LED headlights, there isn’t a single exterior light that isn’t one of your PCB-LED’s. Attached thumbnail(s) Attached image(s)
| gothspeed |
Jan 22 2018, 01:55 PM
#18
Just thought I'd post some pics of the # 2 option above. (IMG:style_emoticons/default/smile.gif)
Edit: just adding a quote of a later post that mentions tire sizes for this yellow tribute (IMG:style_emoticons/default/smile.gif) .............................................. I "talked" to Eric Shea and he is using 195/65/15 F and 215/60/15 R on his beautiful yellow 914-6 GT...this was mainly because he had some 7/8x15 Fuchs with tires on them from a 911 and they worked and no added extra expense....I'm all for that. .......................................... Attached thumbnail(s) Attached image(s)
| mepstein |
Jan 22 2018, 02:10 PM
#19
Even better in person.
| gothspeed |
Jan 22 2018, 09:04 PM
#20
Those 17's look much better than I would have thought!
What tire sizes are those? Any spacers? Even better in person. So far I’m the only 7X16 front 9X16 rear. My rears are actually custom built Weidman 8.5X16 but that isn’t a poll choice. My reason for going with these is tire option availability and the fact that it perfectly fills the wheel well in the rear. Tires look great (IMG:style_emoticons/default/smile.gif)! What size tires did you select for your front (7), rear (8.5) x 16? Did you use any spacers? |
Lo-Fi Version | Time is now: 20th September 2026 - 07:19 AM |
