> Heat Exchanger Nut Tool, 914-6 Hex Nut
DennisV
post Aug 20 2026, 09:07 AM
What have you found or fabricated to tighten the 13 ATF hex nut on 914-6 heat exchanger passenger side? I think that's cylinder number 1.
I'm sure this is probably mechanics 101, but I'm having a hard time with it. I've tried every combination of 1/4 socket, u-joint, wobble extender, flex driver I can find. No room for a box or open end wrench as 2 sides are blocked by bracket and pipe. Nothing I've tried provides enough engagement to properly tighten it.
Posts in this topic
DennisV   Heat Exchanger Nut Tool   Aug 20 2026, 09:07 AM
Cairo94507   Hi Dennis, Yeah there is a special wrench that is ...   Aug 20 2026, 09:13 AM
rudedude   SSI included either a 12mm or 13mm z shaped wrench...   Aug 20 2026, 09:23 AM
sixnotfour   best kept secret,, https://www.amazon.com/dp/B0BB8...   Aug 20 2026, 11:05 AM
nivekdodge   best kept secret,, https://www.amazon.com/dp/B0BB...   Aug 20 2026, 06:52 PM
DennisV   best kept secret,, [url=https://www.amazon.com/dp...   Aug 21 2026, 07:33 AM
Steve   I use a stubby 13mm wrench. I did see S wrenches ...   Aug 20 2026, 11:35 AM
mepstein   Often called a distributor wrench   Aug 20 2026, 11:45 AM
DennisV   Often called a distributor wrench Thank you for ...   Aug 21 2026, 07:42 AM
mepstein   Often called a distributor wrench Thank you for...   Aug 21 2026, 10:35 AM
sixnotfour   The support strap needs the hole slotted so it can...   Aug 20 2026, 12:14 PM
Superhawk996   and your studs short.. :agree: Thats going to f...   Aug 20 2026, 01:16 PM
porschetub   and your studs short.. :agree: Thats going to ...   Aug 20 2026, 04:40 PM
fixer34   Want to say I used a ratcheting box end, swivel he...   Aug 20 2026, 05:38 PM
mepstein   Yea, unless that’s some sort of optical illusion...   Aug 20 2026, 06:23 PM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?showu...   Aug 22 2026, 09:50 PM
DennisV   Why is the piece of metal under the nut? I can...   Aug 23 2026, 08:07 AM
mepstein   Why is the piece of metal under the nut? I can...   Aug 23 2026, 08:47 AM
Steve   [quote name='DennisV' post='3269391' date='Aug 23...   Aug 23 2026, 12:22 PM
sixnotfour   Dansks version of the bracket... is the odity. Rus...   Aug 23 2026, 02:43 PM
DennisV   Dansks version of the bracket... is the odity. C...   Aug 24 2026, 09:39 AM
DennisV   As a follow-up for anyone else that heads down thi...   Nov 13 2026, 09:19 AM
2 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 23rd November 2026 - 07:05 AM
