| bajafreaks |
Sep 11 2026, 04:54 PM
Member ![]() ![]() Group: Members Posts: 171 Joined: 7-February 14 From: Gardnerville, Nevada Member No.: 16,969 Region Association: Northern California |
I'm in need of a 17mm or 19mm master cylinder ATE in excellent/new condition. Hoping someone has an extra one laying around (I know wishful thinking) but I'm having a hard time paying $600+ that vendors are charging, if they even have any available. Thanks
| Mitox |
Sep 11 2026, 09:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 575 Joined: 26-October 15 From: SW Virginia Member No.: 19,302 Region Association: South East States
| DC_neun_vierzehn |
Sep 12 2026, 04:01 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
@914Sixer had a stash of 17MM MCs. Not sure if he has any left.
| 914Sixer |
Sep 12 2026, 06:20 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,587 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Autohausaz, not correct. Sold the stash.
| bajafreaks |
Sep 12 2026, 07:34 AM
Autohausaz, not correct. Sold the stash. And the company you sold them to wants $600+ (IMG:style_emoticons/default/sad.gif) |
| aturboman |
Sep 12 2026, 08:19 AM
Member ![]() ![]() Group: Members Posts: 171 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
| bajafreaks |
Sep 12 2026, 01:59 PM
I have the clip off of my 17mm can you confirm it will work on this 19mm? I honestly dont know the difference between a 17 and 19. |
| aturboman |
Sep 12 2026, 02:45 PM
Yes it will. other than the bore they are identical cylinders
| mepstein |
Sep 12 2026, 03:02 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,927 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I don’t know why the ATE MC’s are $600+. It’s not like the design changed in the last couple decades. They are out of stock at our distributor. Maybe when they become available again th we price will go back to a more normal level.
| Ninja |
Sep 12 2026, 04:16 PM
Member ![]() ![]() Group: Members Posts: 323 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
If they come back...
I see this type of crap often now. I bought the last aftermarket Sanden compressor for a 2010 CRV this spring. Sold it to my customer at $600 and made a small profit. I believe Sanden has stopped making them. Honda themselves is the ONLY source for this compressor now, they have plenty. The Honda list is $2240... 2000-2010 GM truck blend door actuators went from $80 to $350. Most setups have two of these. The bean counters are pricing rare parts (anything over 10 years old) at 5 times what they should be and DO NOT appear to be interested in producing more. That CRV went to a Honda dealer first for its AC problem. Came back with an $8500 estimate for AC work alone. That "totals" the car. I replaced the noisy compressor and completed ALL of the car's PMs for less than 2K. That does not total the car, and the owners should get another 5 years out of it. That dealership aggressively tried to sell them a new CRV... I'd love to be proven wrong, but I believe we've seen the last of the $200 ATE masters. |
| 914werke |
Sep 12 2026, 06:15 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,764 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Yes it will. other than the bore they are identical cylinders Not even close to being accurate. (IMG:style_emoticons/default/chair.gif) |
| Ninja |
Sep 12 2026, 06:58 PM
Yes it will. other than the bore they are identical cylinders Not even close to being accurate. (IMG:style_emoticons/default/chair.gif) Made me look... I have a new ATE 19mm and my original 17 which I've already torn down. The castings appear identical. All ports line up exactly. The ID of the clip bore is 27mm on both. The clips are identical. The one that is in the classifieds will accept your current hardware. It will be an increase in bore size which does change how the pedal feels. The brake activation point in the stroke will be a little higher. The leg force required will be slightly higher. Most folks find it completely usable. Strangely the new ATE cylinder came with the reservoir line bushings installed but the washers which live underneath them in a bag... Make sure to verify washer installation before you assemble it. The old washers out of your original cylinder should work fine if that unit is missing them. |
| mepstein |
Sep 12 2026, 07:29 PM
Yea, big mistake to leave out the spacer washers.
| bajafreaks |
Sep 13 2026, 09:44 AM
Yes it will. other than the bore they are identical cylinders Not even close to being accurate. (IMG:style_emoticons/default/chair.gif) Made me look... I have a new ATE 19mm and my original 17 which I've already torn down. The castings appear identical. All ports line up exactly. The ID of the clip bore is 27mm on both. The clips are identical. The one that is in the classifieds will accept your current hardware. It will be an increase in bore size which does change how the pedal feels. The brake activation point in the stroke will be a little higher. The leg force required will be slightly higher. Most folks find it completely usable. Strangely the new ATE cylinder came with the reservoir line bushings installed but the washers which live underneath them in a bag... Make sure to verify washer installation before you assemble it. The old washers out of your original cylinder should work fine if that unit is missing them. Thanks for the info, wasnt aware of the washers you mentioned. |
| 914werke |
Sep 13 2026, 12:08 PM
I recently had a MC failure of one of the 17mm repop MC's
Because the I am the curious sort I tore into it to figure out why. Since i was essentially rebuilding a MC I also pulled out a couple used units to compare elements, An OE ATE 17 & 19. Other that than the Manufacture cast logo the repop 17 was effectively identical to the OE unit. The 19. is specifically different to an 17mm MC in several ways Aside from the mm designation cast into the neck of the unit, the body is wider, the bore is obviously greater but, the main plunger assembly is slightly different. The secondary bore components are also different. Under the end cap of the the 17 uses a 4 piece assembly (springs F&R & seal pins x2) while the 19 uses a single pin/rod with a single spring. I didnt bother to pull the welch plugs but anticipate difference there as well The external fittings ARE the same but anything intrinsic to the operation of the MC are specific and NOT interchangable |
| aturboman |
Sep 20 2026, 03:02 PM
#16
914-4 (early) and 914-6 use all the same hard brake lines to the master, pedal assembly parts (except throttle lever), brake push rod, reservoir, etc
914-4 came stock with a 17mm and 914-6 with a 19mm ATE cylinder. In the 20+ cars I've personally been involved with, being converted to 911 suspensions and brakes over 30+ years we simply bought a new 19mm ATE 911 master cylinder (901 355 012 00) and anything bolt in. What ever the nuanced differences may be with the castings or internal components they definitely did not impact the physical interchangeably in the past. On a side note in 1969 only there was a 20mm brake cylinder used only on the S models. These also interchanged directly with 914, 912, 911 when we could still get them many years ago. |
| rjames |
Sep 20 2026, 06:00 PM
#17
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,477 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
I recently had a MC failure of one of the 17mm repop MC's Because the I am the curious sort I tore into it to figure out why. Since i was essentially rebuilding a MC I also pulled out a couple used units to compare elements, An OE ATE 17 & 19. Other that than the Manufacture cast logo the repop 17 was effectively identical to the OE unit. The 19. is specifically different to an 17mm MC in several ways Aside from the mm designation cast into the neck of the unit, the body is wider, the bore is obviously greater but, the main plunger assembly is slightly different. The secondary bore components are also different. Under the end cap of the the 17 uses a 4 piece assembly (springs F&R & seal pins x2) while the 19 uses a single pin/rod with a single spring. I didnt bother to pull the welch plugs but anticipate difference there as well The external fittings ARE the same but anything intrinsic to the operation of the MC are specific and NOT interchangable So why did the mc fail? I bought one of them, too. Would like to know if it's functional. |
| euro911 |
Sep 21 2026, 08:38 AM
#18
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,945 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
I still have a couple of new 19mm ATE M/Cs here
| Jack Standz |
Sep 21 2026, 11:53 AM
#19
Senior Member ![]() ![]() ![]() Group: Members Posts: 938 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
I'm in need of a 17mm or 19mm master cylinder ATE in excellent/new condition. Hoping someone has an extra one laying around (I know wishful thinking) but I'm having a hard time paying $600+ that vendors are charging, if they even have any available. Thanks Warning: do not do anything with your brakes, if you do not know what you are doing! With that said, if $600 is too much, how about $40?? It does require rebending the hydraulic brake line (or splurge and get a short new piece). 357 611 019 https://www.rockauto.com/en/moreinfo.php?pk...JvP2sUsoJenvLHV Or https://www.rockauto.com/en/moreinfo.php?pk...JvP2sUsoJenvLHV Here's a write up and, of course there are other options for master cylinders too (search is your friend): http://www.914world.com/bbs2/index.php?showtopic=312451 |
Lo-Fi Version | Time is now: 10th October 2026 - 08:50 AM |
