> Relay board cover, Fitting?
TonyH
post Sep 2 2026, 09:36 AM
Region Association: France
Good afternoon everyone,
Perhaps a strange question..... I have just received my new shiny replacement relay board cover. It obviously requires a technique to fit it nicely.
Before I break it, is it necessary to remove the voltage regulator before it will slip into position? It does seem to be a very tight fit against the rear cabin bulkhead.
Very many thanks in advance,
Tony
sixnotfour
post Sep 2 2026, 09:55 AM
914 Wizard
Region Association: NineFourteenerVille
There is 2 styles.. If you have retractable seat belts you need the one with a slope on the front, to allow it to slide down onto relay board..
NARP74
post Sep 2 2026, 12:27 PM
Region Association: Rocky Mountains
Early and late.
bdstone914
post Sep 2 2026, 09:09 PM
bdstone914
It is not needed to remove the voltage regulator to install the cover.
The late style cover works on all years. The early cover onlyvworks on cars with fixed seat belts.
TonyH
post Sep 3 2026, 03:23 AM
Very many thanks to everyone, it appears that I have an early cover.... what a pain. It was the only one advertised.
I can't afford to keep paying the FedEx pension fund! I will try and modify the early one.
Any tips would be welcome.
- Lo-Fi Version Time is now: 23rd September 2026 - 12:32 AM
